List of Extensions is missing
I have recently upgraded a site from 9.1.1 to 9.2.2.  Everything works as expected except for the Extensions page.
The list of extensions is missing (all of them) and I cannot install new module versions (upgrade).
Thinking that the .dlls were missing or the wrong version from Dnn.PersonaBar.Extnsions.dll I copied those in again, but that did not fix the issue.
I can't copy in the screenshot of the extensions page but each row is blank where the extensions list is generally shown
Has anyone else seen this issue and what is the fix?
Are you seeing any errors, either in the Admin Log or in the browser's developer tool console?
Are other Persona Bar items working normally?
No other errors in Admin Log or developer console.
All other persona bar items work normally except for the extensions page.  In the installed extensions tab, nothing renders in the list, regardless of the "Showing" dropdown list.
In the available extensions tab, I'm stuck with this message regardless of the dropdown list
One sec...We are fetching your extensions
Your extensions will be here in a just a moment
That error message is an indication that the Extensions thing is having trouble getting data from the website. The Person Bar things (not sure what they are called) make webservice calls to get data.
Hang on...on the available extensions, developer console shows this error
Uncaught TypeError: Cannot read property 'replace' of undefined
    at v (:4:18798)
    at d._constructComponentWithoutOwner (export-bundle.js?cdv=296:183)
    at d._constructComponent (export-bundle.js?cdv=296:183)
    at d.mountComponent (export-bundle.js?cdv=296:183)
    at Object.mountComponent (export-bundle.js?cdv=296:19)
    at h.mountChildren (export-bundle.js?cdv=296:184)
    at h._createInitialChildren (export-bundle.js?cdv=296:183)
    at h.mountComponent (export-bundle.js?cdv=296:183)
    at d.performInitialMount (export-bundle.js?cdv=296:183)
In the installed extensions, the developer console just shows warnings are jquery deprecated
JQMIGRATE: Migrate is installed with logging active, version 3.0.0
jquery-migrate.js?cdv=296:62 JQMIGRATE: jQuery.expr[":"] is now jQuery.expr.pseudos
migrateWarn @ jquery-migrate.js?cdv=296:62
get @ jquery-migrate.js?cdv=296:75
(anonymous) @ jquery-ui.js?cdv=296:1249
(anonymous) @ jquery-ui.js?cdv=296:14
(anonymous) @ jquery-ui.js?cdv=296:16
jquery-migrate.js?cdv=296:64 console.trace
migrateWarn @ jquery-migrate.js?cdv=296:64
jquery-migrate.js?cdv=296:62 JQMIGRATE: jQuery.expr.filters is now jQuery.expr.pseudos
(anonymous) @ jquery-ui.js?cdv=296:17054
(anonymous) @ jquery-ui.js?cdv=296:17697
jquery-migrate.js?cdv=296:62 JQMIGRATE: jQuery.fn.bind() is deprecated
bind @ jquery-migrate.js?cdv=296:419
bind @ jquery.history.js?cdv=296:1
h.initCore @ jquery.history.js?cdv=296:1
h.init @ jquery.history.js?cdv=296:1
(anonymous) @ jquery.history.js?cdv=296:1
angular.min.js?cdv=296:305 WARNING: Tried to load dnnsfAngular15 more than once.
jquery-migrate.js?cdv=296:62 JQMIGRATE: jQuery.fn.load() is deprecated
jQuery.fn. @ jquery-migrate.js?cdv=296:386
(anonymous) @ script.js:42
jquery-migrate.js?cdv=296:62 JQMIGRATE: jQuery.fn.delegate() is deprecated
delegate @ jquery-migrate.js?cdv=296:427
$.fn.dnnComposeMessage @ ComposeMessage.js?cdv=296:77
CoreMessaging.init @ CoreMessaging.js?cdv=296:1026
(anonymous) @ 12:1246
mightThrow @ jquery.js?cdv=296:3583
process @ jquery.js?cdv=296:3651
setTimeout (async)
(anonymous) @ jquery.js?cdv=296:3689
fire @ jquery.js?cdv=296:3317
fireWith @ jquery.js?cdv=296:3447
fire @ jquery.js?cdv=296:3455
ready @ jquery.js?cdv=296:3920
completed @ jquery.js?cdv=296:3930
setTimeout (async)
jquery-migrate.js?cdv=296:62 JQMIGRATE: jQuery.unique is deprecated, use jQuery.uniqueSort
processClassString @ jquery-ui.js?cdv=296:517
_classes @ jquery-ui.js?cdv=296:534
_toggleClass @ jquery-ui.js?cdv=296:569
_addClass @ jquery-ui.js?cdv=296:557
_create @ jquery-ui.js?cdv=296:14792
(anonymous) @ jquery-ui.js?cdv=296:144
_createWidget @ jquery-ui.js?cdv=296:341
$.. @ jquery-ui.js?cdv=296:99
(anonymous) @ jquery-ui.js?cdv=296:281
each @ jquery.js?cdv=296:362
each @ jquery.js?cdv=296:157
$.fn. @ jquery-ui.js?cdv=296:273
(anonymous) @ dnn.jquery.js?cdv=296:34
$.fn.dnnTabs @ dnn.jquery.js?cdv=296:11
CoreMessaging.init @ CoreMessaging.js?cdv=296:1042
setTimeout (async)
setTimeout (async)
jquery.js?cdv=296:9455 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
send @ jquery.js?cdv=296:9455
ajax @ jquery.js?cdv=296:9173
jQuery.ajax @ jquery-migrate.js?cdv=296:191
self.getTotals @ CoreMessaging.js?cdv=296:988
CoreMessaging.init @ CoreMessaging.js?cdv=296:1051
setTimeout (async)
jquery-migrate.js?cdv=296:62 JQMIGRATE: jQuery.fn.size() is deprecated; use the .length property
jQuery.fn.size @ jquery-migrate.js?cdv=296:151
window.tpInitBootstrapLayout @ tabspro.js?cdv=296:105
(anonymous) @ 12:508
setTimeout (async)
setTimeout (async)
