Max File Upload not above 28 Mb DNN 9
You can configure the max file upload with the security settings, but a value above 28 Mb is not accepted. So I changed the settings in the web.config (maxRequestLength), but only values below 28 Mb are reflected in the UI security settings, and what's a bigger problem, also not reflected in the file upload within the site assets.
Is this a bug? (I've checked versions from 9.3.2 uptil 9.81 but no improvement on this subject).
Hi Peter,
I found this in the code of DNN, in the method DotNetNuke.Common.Utilities.Config.GetMaxUploadSize:
[code]
if (httpNode == null && Iis7AndAbove())
    const int DefaultMaxAllowedContentLength = 30000000;
    return Math.Min(maxRequestLength, DefaultMaxAllowedContentLength);
[/code]
So it's definitely intentional, but I don't know why that is. Maybe you can create an issue on GitHub so it can be discussed wether or not this is something to fix?
On IIS7+ you need to add a node to specify the maxAllowedContentLength for requests.
(maxAllowedContentLength  = Bytes)
Add this to your web.config:
<code><system.webserver><security></security></system.webserver></code>< system.webServer>
    < security>
      < requestFiltering>
        < requestLimits maxAllowedContentLength="2147483647" />
      < /requestFiltering>
    < /security>
< /system.webServer>
But even then, DNN still seems to use 30000000 as a maximum...
DNN ver. 09.10.02
So is it possible to upload files over 28Mb ?
Hi Peter,
You can set the maximum file upload size use the method mentioned in the following page:
https://dnnsupport.dnnsof...mum-File-Upload-Size
Best regards,
Linda
Website: https://www.dnngo.net
E-mail account: [email protected]
Skype: dnngo-linda
Hi Peter,
Best regards,
Linda
Skype: dnngo-linda
