I'm not able to change the default workflow of Html/Text module to "Content Staging" if I select "Module" option for "Apply workflow to". No errors in the "Admin Logs" and the saving do nothing. I tried if I selecting "Page" option for "Apply workflow to" and that's saved correctly. Only "Page" option works for me. (I did't try "Site" option because this is not what I would like for my entire Website. I don't like the "Page" option when I have a page with a lot of Html/Text but for the moment I don't have choice.)
Do you have this issue? And, if yes, do you have a solution?
(This past winter, I successfully upgraded DNN Platform 8.0.4 to 9.2.2 and this is the first time with 9.2.2 that I have had to change these settings in a page. I had done it many times with 8.0.4.)
I just tried this in DNN Platform 9.2.2 and it worked as expected. Here are the steps to enable and use workflow in DNN Platform's HTML/Text module.
From there, I was able to verify that the settings saved. I also verified that they were working by doing the following:
I hope this helps. :)
Hi Sylvain and Will, We have a DNN 9.3.2 site, and never used the Workflow-option (didn't know it existed). But: I have the same issue als Sylvain: i can change the setting on Page level, not on Module level. If I change the setting, choose module, tick the 'replace current settings' box, than Save: i return to the page. But if I then go to settings, I see that the setting isn't changed. If I chools Page instead of Module, the settings do change. As i said: i have never used this option before, so is there some setting elsewhere that I have to change?
Did you ever find a solution? sincerely, Sytske van Hasselt, Amsterdam
Sorry to resurrect an old thread, but I'm having similar problems trying to use content staging in DNN Platform 9.7.2
If I change any HTML Module's Settings to Workflow: Content Staging and save, it just reverts to Direct Publish when I go back into the settings. It doesn't matter whether I select Module, Page or Site or whether "Replace Existing Settings" is ticked,.
It would be useful to have a Draft option for either pages or modules, but I have yet to see it!
Aha! I just figured out what you're running into. I was creating a video to show you how I get it to work, but the Module option appears to be ignored and the settings not retained for the workflow switch. The other options appear to work as expected.
I was going to suggest this get logged as a bug, but it's already reported and triaged.
https://github.com/dnnsof...Platform/issues/3009
