DNN For YAF Uninstalled & Can't Delete Users Now
Hey Everyone:
If you're running or know DNN for YAF, I have this pressing issue that I need a bit of help with.  Thanks in advance!  :)
https://yetanotherforum.n...elete-Superusers-Now
Will,
I had the same problem a while ago, and I don't remember exactly what it was (and unfortunately I did not document it anywhere) - but I think that YAF modified one of the DNN Stored procedures (RemoveUser?), and deleting this procedure and re-creating it from the original DNN script did the trick.
Hope that helps...
Aha!  I should've thought to search through the sprocs.  You were correct about this.  The RemoveUsers procedure was modified.  This is a core code change.  Had I known this was happening, I wouldn't have ever even tried using this module.  :(
It was the only sproc that had the term <code>yaf</code> in it.  I used these queries to find it:
<code>SELECT OBJECT_NAME(object_id)<br />     FROM sys.sql_modules<br />     WHERE OBJECTPROPERTY(object_id, 'IsProcedure') = 1<br />     AND definition LIKE '%yaf%'</code>
<code>SELECT OBJECT_NAME(id) <br />     FROM SYSCOMMENTS <br />     WHERE &#91;text&#93; LIKE '%yaf%' <br />     AND OBJECTPROPERTY(id, 'IsProcedure') = 1 <br />     GROUP BY OBJECT_NAME(id)</code>
<code>SELECT ROUTINE_NAME, ROUTINE_DEFINITION<br />     FROM INFORMATION_SCHEMA.ROUTINES <br />     WHERE ROUTINE_DEFINITION LIKE '%yaf%' <br />     AND ROUTINE_TYPE='PROCEDURE'</code>
I used a clean instance of DNN 9.12 (same version) to drop and recreate the sproc:
<code>/****** Object:  StoredProcedure &#91;dbo&#93;.&#91;RemoveUser&#93;    Script Date: 8/31/2023 9:07:40 AM ******/<br /> DROP PROCEDURE &#91;dbo&#93;.&#91;RemoveUser&#93;<br /> GO</code>
<code>/****** Object:  StoredProcedure &#91;dbo&#93;.&#91;RemoveUser&#93;    Script Date: 8/31/2023 9:07:40 AM ******/<br /> SET ANSI_NULLS ON<br /> GO</code>
<code>SET QUOTED_IDENTIFIER ON<br /> GO</code>
<code>CREATE PROCEDURE &#91;dbo&#93;.&#91;RemoveUser&#93;<br />     @UserID        int,<br />     @PortalID   int<br /> AS<br />     IF @PortalID IS NULL<br />         BEGIN<br />             -- Delete SuperUser<br />             DELETE FROM dbo.Users<br />                 WHERE  UserId = @UserID<br />         END<br />     ELSE<br />         BEGIN<br />             -- Remove User from Portal<br />             DELETE FROM dbo.UserPortals<br />                 WHERE  UserId = @UserID<br />                  AND PortalId = @PortalID<br />             IF NOT EXISTS (SELECT 1 FROM dbo.UserPortals WHERE  UserId = @UserID)<br />                 -- Delete User (but not if SuperUser)<br />                 BEGIN<br />                     DELETE FROM dbo.Users<br />                         WHERE  UserId = @UserID<br />                             AND IsSuperUser = 0<br />                     DELETE FROM dbo.UserRoles<br />                         WHERE  UserID = @UserID<br />                 END<br />             ELSE<br />                 BEGIN<br />                     DELETE ur FROM dbo.UserRoles ur<br />                         INNER JOIN dbo.Roles r ON r.RoleID = ur.RoleID<br />                         WHERE  UserID = @UserID AND r.PortalID = @PortalID<br />                 END<br />         END<br /> GO</code>
These are superusers I'm attempting to permanently remove, so far.  They're already marked as deleted, but I still can't use the option in the Users view to "Permanently Delete."  I get a new error, listed below.  However, an interesting thing to note is that running the <code>purge- user</code> prompt command doesn't display any error at all.  If I took that for it's word, the same user accounts I'm trying to delete are deleted, but they're still there.
ERROR MESSAGE
<code>Message:Internal Query Processor Error: The query processor encountered an unexpected error during execution (HRESULT = 0x80040e19).</code>
<code>StackTrace:</code>
<code>   at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)<br />    at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)<br />    at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)<br />    at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted)<br />    at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)<br />    at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)<br />    at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)<br />    at System.Data.SqlClient.SqlCommand.ExecuteNonQuery()<br />    at PetaPoco.Database.<>c.<ExecuteNonQueryHelper>b__353_0(IDbCommand c)<br />    at PetaPoco.Database.CommandHelper(IDbCommand cmd, Func`2 cmdFunc)<br />    at PetaPoco.Database.ExecuteNonQueryHelper(IDbCommand cmd)<br />    at PetaPoco.Database.ExecuteInternal(CommandType commandType, String sql, Object&#91;&#93; args)<br />    at DotNetNuke.Data.PetaPoco.PetaPocoHelper.ExecuteNonQuery(String connectionString, CommandType type, Int32 timeoutSec, String sql, Object&#91;&#93; args)<br />    at DotNetNuke.Data.SqlDataProvider.ExecuteNonQuery(String procedureName, Object&#91;&#93; commandParameters)<br />    at DotNetNuke.Security.Membership.AspNetMembershipProvider.RemoveUser(UserInfo user)</code>
This means that there are likely MORE core code changes that were made.  Ugh...
