HTMLEditorManager not working after upgrade to DNN 9.2.2
Hi - I'm testing upgrade from DNN 9.1.1 to DNN 9.2.2 -
After the upgrade, the HTML Editor Manager doesnt show up. I try to access it here: http://[websitename]/host/HtmlEditorManager.aspx
I was able to access the manager on the site before upgrading.
Any insight into this would be appreciated! Thanks
Tom
I see these two Errors in Admin logs each time I try to access the URL:
-----------------------------------------------------------First error -------------------------------------------------------------------------------------------------------------
ModuleId:8582
ModuleDefId:160
FriendlyName:HTML Editor Manager
ModuleControlSource:DesktopModules/Admin/HtmlEditorManager/Views/ProviderConfiguration.ascx
AbsoluteURL:/Default.aspx
ExceptionGUID:c8a3dd7c-a383-419f-9172-a99f68d0885f
AssemblyVersion:9.2.2
PortalId:0
UserId:389
TabId:2080
RawUrl:/Default.aspx?tabid=2080&def=ErrorMessage
Referrer:
UserAgent:Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/77.0.3865.90 Safari/537.36
ExceptionHash:4GHfz7sdYigiPhrR8+zaQ0GZJqI=
Message:The given key was not present in the dictionary.
StackTrace:
InnerMessage:The given key was not present in the dictionary.
InnerStackTrace:
at System.ThrowHelper.ThrowKeyNotFoundException() at System.Collections.Generic.Dictionary`2.get_Item(TKey key) at DNNConnect.CKEditorProvider.Helper.TreeViewHelper`1.RefreshTreeViewNodes(TreeNodeCollection treeViewNodes, Func`2 parentIdCheck, Dictionary`2 allLeaves) at DNNConnect.CKEditorProvider.Module.EditorConfigManager.LoadNodesByTreeViewHelper(List`1 editorHostSettings, TreeNode portalNode, Dictionary`2 modulesNodes, List`1 tabs) at DNNConnect.CKEditorProvider.Module.EditorConfigManager.RenderPortalNode(PortalInfo portal, ModuleController moduleController, List`1 editorHostSettings, TreeNode parentNode) at DNNConnect.CKEditorProvider.Module.EditorConfigManager.BindPortalTabsAndModulesTree() at DNNConnect.CKEditorProvider.Module.EditorConfigManager.InitializeComponent()
Source:
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
Server Name: SCTAS35
-----------------------------------------------------------------Second Error -------------------------------------------------------------------------------------------------
ExceptionGUID:7bef4ede-3477-4cb8-8eb7-2aaed3f8b7f9
PortalId:0
UserId:389
TabId:2080
Referrer:
ExceptionHash:AA+oM2/pTVU31GxC+hRPiz9UR9c=
Message:The Controls collection cannot be modified because the control contains code blocks (i.e. <% ... %>).
StackTrace:
InnerMessage:The Controls collection cannot be modified because the control contains code blocks (i.e. <% ... %>).
InnerStackTrace:
   at System.Web.UI.ControlCollection.Add(Control child)
   at
DotNetNuke.Services.Exceptions.Exceptions.ProcessModuleLoadException(String
 FriendlyMessage, Control ctrl, Exception exc, Boolean
DisplayErrorMessage)
Source:
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
this was a known issue in DNN 9.3. I suggest upgrading to DNN 9.4.1
I an running DNN 9.2.2 and seeing this issue - Is there a way to fix it before upgrading to 9.3 and 9.4?
Thanks!
Tom
Or a way to work around it?
I found out that I can get to the editor config in the "Custom Editor Options" link directly under the editor itself (even though the Site settings link doesnt work)
