Resource Manager is not using resx files?
 25 Subscribed to this forum
I created a language pack for the Resource Manager (de-AT). For some sites it works, for some not.
I tried to figure out where the reason is, uninstalled the package and reinstalled it - still the English labels. I double-checked the file permissions and the entries in the database. I found no errors or warnings in the developer tools console. Finally, I changed the line in ResourceManager.resx (not ResourceManager.de-at.resx!) from
<code><data name="AddFolder.Text" xml:space="preserve"><br />   <value>Add Folder</value><br /> </data> </code>
to
<code><data name="AddFolder.Text" xml:space="preserve"><br />   <value>Blah!</value><br /> </data> </code>
After a restart of the application pool, clearing the cache (on the server and in the browser) and reloading the page, it still shows "Add folder".
The stupid thing is: I created this language pack for DNN 9.11.0, and after upgrading to DNN 9.11.1 it has this behaviour. It worked with DNN 9.11.0. And - as I mentioned - this is not the same for all (9.11.1) sites, on some it works, on some not.
Any ideas?
Just checked on my DNN 9.10.2 installation, and it worked fine.
Usually when a resx file is not working it is because of some typo or something.
Perhaps added characters like & instead of &
Also, does this environment happen to be behind any kind of caching server (e.g., reverse proxy, WAF, etc.)? You may need to be sure to clear cache everywhere, including there.
Will's idea it's a pretty good one, I usually get a lot of problems looking at recent changes or fixing things like this when you've cloudflare or features like this enable.
No. Cache is disabled anywhere in my dev environment.
