Issues Upgrading DNN 9.1.1 to 9.2.2
When I try to upgrade DNN 9.1.1 to DNN 9.2.2 , my digital assets sections stop working. I removed all extensions that I'm not currently using. As well as going to the desktop modules /bin folders and deleting files that corresponds with non used extensions.
This the error that shows up in my console:
main.js?cdv=315:51 TypeError: Cannot read properties of undefined (reading '$element')
    at initFileUpload (Assets.js?cdv=315:1061)
    at Object.init (Assets.js?cdv=315:1280)
    at VM82 util.js:31
    at Object.execCb (require.js?cdv=315:1650)
    at Module.check (require.js?cdv=315:861)
    at Module. (require.js?cdv=315:1113)
    at require.js?cdv=315:132
    at require.js?cdv=315:1156
    at each (require.js?cdv=315:57)
    at Module.emit (require.js?cdv=315:1155)
requirejs.onError @ main.js?cdv=315:51
main.js?cdv=315:52 Uncaught TypeError: Cannot read properties of undefined (reading '$element')
    at VM82 util.js:31
I suggest to continue upgrading until DNN latest and replace Digital Assets module by new Ressource Manager (Telerik free)
Posted By Sebastian Leupold on 19 Oct 2021 06:23 PM
@Sebastian Leupold
Thank you for your response. So what you're saying is to try to go through the suggested upgrade path until the latest release. And when I get to the latest release, that's when I replace the Digital Assets Module with the Resource Manager? Thanks for all your help.
Posted By Davidwebdev on 20 Oct 2021 09:21 AM
@Sebastian Leupold
Exactly!
You are welcome :)
