Transfer users
Hi, I have a very old DNN 4.7 website. I have a question - is it possible somehow to transfer users from DNN 4.7 to DNN 9 or 9.1?
I know how to create users programmatically, but I need to preserve User Id and credentials.
Thank you.
AFAIK. there's no way to do this while keeping the UserIds as these are created when the user is created.
You could however search for tables that store the UserId and change that value to the new userid maybe?
Thank you for reply. Is there any option to upgrade DNN 4.7 to DNN 9?
Hi - there is a suggested upgrade path at this link, that has been good for me since v2 days...
https://docs.dnncommunity...rade-path/index.html
Read the release notes, backup (database and files) at each stage so you can recover if something goes wrong, and don't be tempted to skip stages.
Hi Alex
Not sure if this helps, and I cannot remember the original version of DNN I started with but it was a system I started in 2016/17.
I have system, for volunteer drivers, where users have a login to DNN but their Roles in the system mean that UserID 1 may be a Coordinator and UserID 2 may be a Driver so DNN UserID = 2 links to DriverID = 1
What I'm interested in is you mention you know programmatically how to add new users. Now originally I had a DNN module that Bulk added users from a CSV file, but since DNN changed the development environment from VB (?) to C (#) that module is no longer supported.
Two questions
1. Have you developed a similar module
2. Do you know the SQL code that adds users
All the best
Dave
Hi, please use this code as an example
Public Function AddUser() As Long
        Dim oUserInfo As New UserInfo
        With oUserInfo
            .PortalID = 0
            .Membership.Username = NickName
            .Profile.FirstName = FirstName
            .Profile.LastName = LastName
            .Membership.Email = Email
            .Email = Email
            .Membership.Approved = True
            .AffiliateID = Null.NullInteger
            If Me.IsRandomPassword = False Then
                .Membership.Password = Password
                .Membership.PasswordQuestion = "aaa"
                .Membership.PasswordAnswer = "bbb"
            Else
                Password = UserController.GeneratePassword
            End If
            .Profile.ProfileProperties("Facility").PropertyValue = Facility
            .Profile.ProfileProperties("Street").PropertyValue = Me.Address
            .Profile.ProfileProperties("Unit").PropertyValue = Me.Apartment
            .Profile.ProfileProperties("City").PropertyValue = Me.City
            .Profile.ProfileProperties("Region").PropertyValue = Me.State
            .Profile.ProfileProperties("PostalCode").PropertyValue = Me.Zip
            .Profile.ProfileProperties("Zip4").PropertyValue = Me.Zip4
            .Profile.ProfileProperties("Telephone").PropertyValue = Me.HomePhone
            .Profile.ProfileProperties("WorkPhone").PropertyValue = Me.WorkPhone
            .Profile.ProfileProperties("Cell").PropertyValue = Me.CellPhone
            .Profile.ProfileProperties("DOB").PropertyValue = Me.DOB
            .Profile.ProfileProperties("SSN").PropertyValue = Me.SSN
            .Profile.ProfileProperties("Sex").PropertyValue = Me.Sex
            .Profile.ProfileProperties("LanguagePreferences").PropertyValue = Me.LanguagePreference
            .Profile.ProfileProperties("Language").PropertyValue = Me.Language
            .Profile.ProfileProperties("Supervisor").PropertyValue = Supervisor
            .Profile.ProfileProperties("AvailableDepartments").PropertyValue = AvailableDepartments
            .Profile.ProfileProperties("Extension").PropertyValue = Me.Extension
            .DisplayName = oUserInfo.FirstName & " " & oUserInfo.LastName
        End With
        Dim createStatus As UserCreateStatus = UserController.CreateUser(oUserInfo)
        If createStatus = UserCreateStatus.Success Then
            Dim MyID As Long = oUserInfo.UserID
            Dim Role As New RoleInfo
            Role = Me.RoleByName("Registered Users")
            Dim PortalSettings As New PortalSettings
            RoleController.AddUserRole(oUserInfo, Role, PortalSettings, Null.NullDate, Null.NullDate, MyID, False)
            If CityAdmin Then
                Role = Me.RoleByName("City Administrators")
            ElseIf Inspector Then
                Role = Me.RoleByName("Audit Inspector")
                RoleController.AddUserRole(oUserInfo, Role, PortalSettings, EffectiveDate, ExpiryDate, MyID, False)
            Else
                Dim RoleNames() As String = RoleName.Split(",")
                For r As Integer = 0 To RoleNames.Length - 1
                    Role = Me.RoleByName(RoleNames(r))
                Next
            End If
            Return MyID
        End If
    End Function
As Timo mentioned, there's no "easy" way to move users from DNN 4.x to a more recent version like 9.xx. It would have to be something where you build a connection to "import" the users via code, as you suggested.
As far as upgrading, it can certainly be done. In fact, we've done a handful of 4.xx upgrades last year. Though, depending on the website, it may be more economical to just rebuild the website and import the users.
