Suddenly "Web Server Updated" every few minutes on all sites
Page 2 of 3 << < 123 > >>
It sounds like we might be at the point where an Issue should be created in GitHub.  This is too consistent for those experiencing it.  There must be a newly introduced feature/bug in 9.11.02 that needs to be looked at.
I'm wondering if Localization has anything to do with this too... Are these sites using multiple languages as well?
Thanks a lot for your precious time and investigation!
25% of all sites are multilingual, 75% are not.
My site is in Dutch, nothing else
I'm seeing this on a (single language) site too
Are there any other impacts resulting from this issue, other than perhaps larger log files? Would this be a reason not to upgrade to 9.11.2?
Ok I think this is caused by the newly introduced "Monitor Web Servers"  scheduled task.
https://github.com/dnnsof...Platform/issues/5575
https://github.com/dnnsof...n.Platform/pull/5586
If I understand correctly this is only needed on multi server environments.
On a single server you could disable the task or set the frequency to once a day.
After I did that the "webserver updated" admin log entries stopped showing up.
FYI, I also found this "issue".
https://github.com/dnnsof...Platform/issues/5634
I deleted that task and now get this:
04/29/2023 19:59:20
Scheduler Exception
AbsoluteURL DefaultDataProvider DotNetNuke.Data.SqlDataProvider DotNetNuke
AbsoluteURL:
ExceptionGUID:dc73c5bf-7309-4df1-9fdd-c81316336343
AssemblyVersion:
PortalId:-1
UserId:-1
TabId:-1
RawUrl:
Referrer:
UserAgent:
ExceptionHash:QYyt2knVhnhKZyrIMBDaSbPHh8g=
Message:Sequence contains no elements
StackTrace:
at System.Linq.Enumerable.First[TSource](IEnumerable`1 source)
at DotNetNuke.Services.Scheduling.Scheduler.CoreScheduler.ValidateServersAreActiveForScheduledItem(ScheduleItem scheduleItem)
at DotNetNuke.Services.Scheduling.Scheduler.CoreScheduler.AddToScheduleQueue(ScheduleHistoryItem scheduleHistoryItem)
at DotNetNuke.Services.Scheduling.Scheduler.CoreScheduler.LoadQueueFromTimer()
at DotNetNuke.Services.Scheduling.Scheduler.CoreScheduler.Start()
InnerMessage:
InnerStackTrace:
Source:System.Core
FileName:
FileLineNumber:0
FileColumnNumber:0
Method:
Server Name: IIS
I got the same error as Mariette every 10 minutes after setting the frequency to once a day.
After recycling the application pool, the message was terminated.
Posted By Timo Breumelhof - 40FINGERS on 4/28/2023 4:31 AM
Multi-server and cloud environments like Azure, where your server(s) could change.
This is still an issue. One server, 3 languages and lots of errors in the log like:
I have disabled the task, deleted the task, recreated the task but it keeps coming back.
