Unable to add module in DNN 9 > Fix
I'm just adding this post for others that might encounter the same issue in DNN.
I have had issues on a DNN 9 site with adding modules in some circumstances.
The issue was that after clicking the "Add Module" icon and selecting a module, I could not frag the module to the right Pane.
Visually after selecting the module, I either saw an empty  square with a dashed / dotted border or
a weird, half transparent preview of the placed module.
But no way to drag the module.
In the browser console you might see a Javascript error on $newModule.offset().
<code>Uncaught TypeError: $newModule.offset() is undefined<br />     _motionToNewModule <a href="https://mywebsite.com/DesktopModules/admin/Dnn.EditBar/Resources/ContentEditorManager/Js/ModuleDialog.js?cdv=380:1091" target="_blank" rel="nofollow">https://mywebsite.com/Des...alog.js?cdv=380:1091</a><br />     _hideDialog <a href="https://mywebsite.com/DesktopModules/admin/Dnn.EditBar/Resources/ContentEditorManager/Js/ModuleDialog.js?cdv=380:397" target="_blank" rel="nofollow">https://mywebsite.com/Des...ialog.js?cdv=380:397</a><br />     jQuery 25<br />     _hideDialog <a href="https://mywebsite.com/DesktopModules/admin/Dnn.EditBar/Resources/ContentEditorManager/Js/ModuleDialog.js?cdv=380:395" target="_blank" rel="nofollow">https://mywebsite.com/Des...ialog.js?cdv=380:395</a><br />     close <a href="https://mywebsite.com/DesktopModules/admin/Dnn.EditBar/Resources/ContentEditorManager/Js/ModuleDialog.js?cdv=380:67" target="_blank" rel="nofollow">https://mywebsite.com/Des...Dialog.js?cdv=380:67</a><br />     _motionToNewModule <a href="https://mywebsite.com/DesktopModules/admin/Dnn.EditBar/Resources/ContentEditorManager/Js/ModuleDialog.js?cdv=380:1087" target="_blank" rel="nofollow">https://mywebsite.com/Des...alog.js?cdv=380:1087</a><br />     _syncCompleteFunc <a href="https://mywebsite.com/DesktopModules/admin/Dnn.EditBar/Resources/ContentEditorManager/Js/ModuleDialog.js?cdv=380:1051" target="_blank" rel="nofollow">https://mywebsite.com/Des...alog.js?cdv=380:1051</a><br />     _syncComplete <a href="https://mywebsite.com/DesktopModules/admin/Dnn.EditBar/Resources/ContentEditorManager/Js/ModuleDialog.js?cdv=380:1007" target="_blank" rel="nofollow">https://mywebsite.com/Des...alog.js?cdv=380:1007</a><br />     setTimeout handler*_syncComplete <a href="https://mywebsite.com/DesktopModules/admin/Dnn.EditBar/Resources/ContentEditorManager/Js/ModuleDialog.js?cdv=380:1006" target="_blank" rel="nofollow">https://mywebsite.com/Des...alog.js?cdv=380:1006</a><br />    ...<br />     dnnLoadScriptsInAjaxModeComplete <a href="https://mywebsite.com/Reports:1020" target="_blank" rel="nofollow">https://mywebsite.com/Reports:1020</a><br />     loadScriptInSingleMode <a href="https://mywebsite.com/Reports:948" target="_blank" rel="nofollow">https://mywebsite.com/Reports:948</a><br />     <anonymous> https://mywebsite.com/Reports:1001<br /> ModuleDialog.js:1091:38</code>
I had the issue only on specific pages and found out it was caused by an HTML error (an extra < / div>) in the module that was already on the page.
After I fixed the HTML error, placing modules worked correctly again.
I did some tests and not all HTML errors seem to cause this issue.
Also, an HTML error in your Theme might trigger the same issue.
HTH Timo
I also came across this error, but mine wasn't called by invalid HTML - I also found another solution, where if you have conflicting/invalid Site Aliases, it will also cause the Add Module function to fail. Removing the invalid site alias will return the hovering floating tile functionality.
A bit more explanation: the website was unable to save the CEM_NewModuleId cookie because the JavaScript sf_siteRoot variable was invalid, because of this conflict. The Add Module functionality depends on the CEM_NewModuleId cookie in order to figure out which HTML element needs to be converted to "floating".
Invalid sf_siteRoot: "//dnn.lcl" - the browser would not save the cookie and silently ignore this as this is not a matching or is an invalid domain.
Valid sf_siteRoot: "/"
