cannot login using super admin
hi
I have an error after I've upgraded dnn when I'm trying to login using super admin
in the page coming err_too_many_redirects
and in the log this message is coming
[ERROR] DotNetNuke.Services.Exceptions.Exceptions - ~/Default.aspx?tabid=65&def=ErrorMessage
System.Web.HttpException (0x80004005) : The controls collection cannot be modified because the control contains code blocks (i.e. <% . . . %>).
at System.Web.UI.ControlCollection.Add(Control child)
at DotNetNuke.Services.Exceptions.Exceptions.ProcessModuleLoadException(String FriendlyMessage, Control ctrl, Exception exc, Boolean DisplayErrorMessage)
We're gonna need a little bit more...
- From what version to what version?
- Did you take a giant leap or steps?
- What third party modules / themes are you using?
- Multi language?
As Tycho's questions made allude to you, we definitely need to know more in order to be more helpful.  Sometimes, when I run into this, it can be one of the following:
  • The URL provider and/or it's setting(s) in the web.config file (compare yours to a clean installation of the same version of DNN)
  • Bad PortalAlias settings in the PortalAlias table in the database (also check the default alias in the PortalSettings table).
  • A rogue module and/or HttpModule that's controlling URL's.
One thing I sometimes do to help troubleshoot this is to use a tool like Fiddler to instead the requests and responses after turning on debugging (in DNN itself and in the web.config).  It doesn't always help.  That really depends on the underlying issue that's causing the redirects.
