Issue while Upgrading 9.3.2 to 9.8.0
VM
Hello DNN Community,
Thank you everyone for your outstanding job. I have an issue where I upgraded DNN 9.3.2 to 9.8.0 and experiencing the following issues
1. I logged in as Superuser and still not able to see the SQL Config editor ( I can see the buttons) to execute queries.
2. Not able to view any file under the Config Manager
3. I had created a custom theme which was working fine prior to the upgrade. However, after the upgrade, I am not able to access Shortcodes, Typography, and accessibility.
What does your web browser console show- any errors when trying to access the persona bar API? Also check the logs in the ~/portals/_default/logs/ directory
VM
Thanks for your response. My issue is partially solved. I was able to view all the options related to the theme. However, I am still having issues accessing the SQL Config (Editor to write query) and Config Manager ( Editor to view the files). Any help is highly appreciated.
Original post 1 and 2 are still outstanding.
You will still need to check your browser console and the DNN logs to investigate those issues further
VM
I see I see 404 for loader.js,editor.main.js and even when I have editor.main.js under Resources/Shared/components/MonacoEditor/editor/ and loader.js under Resources/Shared/components/MonacoEditor
