The DNN 09.11.01 upgrade will only complete on SQL 2016 and above
DYI,
Today I tried ugrading a DNN 09.10.02 site to 09.11.01 on a server with SQL 2012 and it failed.
There is a SQL script in the install package that can only run SQL 2016+
SQL 2012 is old, but as DNN officially supports SQL 2008+ I created a ticket for this:
https://github.com/dnnsof...Platform/issues/5554
BTW, your site will still run after this, but I would still advise you to restore from backup and either wait for a fix or upgrade SQL server and try again.
Timo,
I answered this in another thread (that I can't find anymore?) already. First of all: SQL Server 2016 and SQL Server 2017 have already passed the mainstream update phase, so you don't get any security updates anymore (except when you pay a lot of money for extended upgrades). Therefore, using SQL Server 2019 or 2022 is the recommended solution.
The problem can be found in the file 09.11.01.SqlDataProvider in the installation package for Dnn.PersonaBar.Extensions, lines 25 and 53. This syntax ("DROP PROCEDURE IF EXISTS"...) was introduced with SQL Server 2016, it was one of the few things I always liked in the Oracle PL/SQL "dialect". What a pity, they did not introduce this consequently. Another example for this is "CREATE OR ALTER PROCEDURE..." - these commands work with Stored Procedures and Functions, at least in SQL Server 2019, but not with Views. :-(
The solution is either upgrade your SQL Server (better way!) or replace the lines with
<code>IF EXISTS (SELECT * FROM sys.objects WHERE object_id = OBJECT_ID(N'{databaseOwner}{objectQualifier}UpdateIPFilter') AND type in (N'P', N'PC'))<br />       DROP PROCEDURE {databaseOwner}{objectQualifier}UpdateIPFilter<br /> GO </code>
and
<code>IF EXISTS (SELECT * FROM sys.objects WHERE object_id = OBJECT_ID(N'{databaseOwner}{objectQualifier}AddIPFilter') AND type in (N'P', N'PC'))<br />       DROP PROCEDURE {databaseOwner}{objectQualifier}AddIPFilter<br /> GO </code>
before you install DNN.
Maybe someone should change the DNN Platform Requirements -- DNN Docs (dnncommunity.org) and eliminate at least SQL Server 2012 and SQL Server 2014, better also 2016 and 2017.
Oh, I thought the most current supported SQL Server version was already 2014 and higher.  🤔
Posted By Will Strohl on 2/27/2023 6:13 PM
Well - that's not in the docs...
Anyway: There is a statement in the setup/upgrade SQL scripts that requires SQL Server 2016 or higher, therefore SQL Servers 2012 and SQL Server 2014 should be excluded from the minimum requirements, at least for DNN version 9.11.1. We should discuss if SQL Servers are supported that are already past the MS Mainstream Support (for security reasons I would say: No), in this case SQL Server 2016 and SQL Server 2017.
The problem is obviously that someone generated that part of the script with the script creation tool in SSMS using a newer SQL Server, and was not aware about the consequences in older SQL Server versions.
