Upgrading from 9.0.2 to 9.4.4
 33 Subscribed to this forum
Gil
After upgrading our DNN site from  9.0.2 to 9.4.4, the log file posted the error below.
DotNetNuke.Services.Exceptions.Exceptions - DotNetNuke.Services.Exceptions.PageLoadException: Unhandled error loading page. ---> System.InvalidOperationException: No service for type 'DotNetNuke.UI.Modules.IModuleControlPipeline' has been registered.
The site comes up properly on initialization; however, on the refresh it shows a 500 internal error.
I have been trying to find and implement ideas on how to resolve this error for many days now, any help would be appreciated!
Which version of ASP.NET is being used?
Gil
ASP.NET 4.0.30319
.NET Framework 4.7.2
So much for Guess #1 ...
Do you use any DNNSharp modules? Any other 3rd party modules?
Gil
We do have custom module that we have created. These modules are precompiled when publishing to our servers.
Perhaps this might be the issue. In version 9.0.2 or less, we usually deployed our site with the setting "Precompile during publishing" using Visual Studio.
With this new version 9.4.4, this precompile setting seems to be generating the error mentioned above. When the precompile setting is unchecked the error message is no longer an issue and the site seems to function properly but with the .cs file present.
So, if you don't use the precompile option, then all is well with your site?
If that's the case, I'd be looking at the module rather than at DNN as the culprit. Or perhaps the precompile option. I'd guess that there's something in your precompile environment (sorry ... but I have no idea how all of that works). Maybe the precompile is targeting the wrong ASP.NET? Or something else. When you don't select that option, then the compile is done in the context of your site, and all is well.
At least that's another guess ... so I'd look there.
