Upgrading from v9.4.4 to 9.10.2 broke Pages on the persona bar and the page settings for every page
I have a website which is currently running DNN 9.4.2. I am planning to upgrade it to the latest (9.10.2). I am currently testing this on my local machine and the upgrade broke the "Pages", which is on the persona bar and the page settings on every page on the portal. When I open up the Pages, it opens a IFrame. The Pages section loads on the IFrame for a fraction of second and then it goes blank. I checked the errors in browser's console and I see 4 errors.
Error 1:
Uncaught TypeError: c is not a function
at u (reducers.ts:107)
at v (reducers.ts:107)
at exports.unstable_runWithPriority (reducers.ts:107)
at cg (reducers.ts:107)
at Jj (reducers.ts:107)
at yj (reducers.ts:107)
at Ig (reducers.ts:107)
at bk (reducers.ts:107)
at reducers.ts:107
at Nj (reducers.ts:107)
Error 2: 2 times the same error
TypeError: Cannot read properties of undefined (reading 'length')
at Object.t.getWeekArray (reducers.ts:107)
at t.value (reducers.ts:107)
at gi (reducers.ts:107)
at fi (reducers.ts:107)
at Rj (reducers.ts:107)
at Qj (reducers.ts:107)
at Kj (reducers.ts:107)
at reducers.ts:107
Error 3:
at t (reducers.ts:107)
at MessagePort.T.port1.onmessage (reducers.ts:107)
I see the same Error 1 on several other pages from persona bar: Users, Roles, Servers. Also, it happens on several other persona bar items intermittently. The error happens on Chrome, Edge and Firefox as well. This site uses angular 10 as well. I don't see any errors on 9.4.1 website on any of the persona bar items. Other than the upgrade, nothing else has changed. I don't have a way to update page settings or create/update pages. Not sure what's going on. Did anyone see this? Can anyone provide any insight into what's going on Or how I go about finding what's causing this error? Also, is there another way I can see and update page settings?
are you using proper version of .Net framework?
Did you clear local browser cache and cookies?
Posted By Sebastian Leupold on 25 Oct 2021 08:20 PM
Thanks for the reply. Sorry for the delay, distracted with something else at work. I was able to check the machine. When I hover over DNN logo on the website, it shows .Net Framework is 4.8. But When I go to Settings on the persona bar Servers -> System Info -> Web section, it shows .Net Framework Version as 4.0.30319.42000. Not sure why they are different. But I do have v4.8.04084 installed on the machine.
I cleared browser cache and cookies, still the issue exists. Any ideas?
please check, PB Settings > Server > Performance, whether DNN client resource management has "combine files" enabled and disable it.
Enable Composite Files and Minify CSS is enabled and Minify JS is disabled. I disabled composite files and Minify CSS files, cleared broweser cookies and cache and still the issue existed. Also, increased the Current Host Version under Client Resource Management and still the issue exists.
did you restart DNN after you made these changes?
I restarted the DNN and this is what I see now, they look the same as the previous errors, but location is different. Is the issue with animations? Is there a way to disable animation on the Personabar pages?
export-bundle.js?cdv=737:38618 Uncaught TypeError: c is not a function
    at u (VM95 export-bundle.js:formatted:93004)
    at v (VM95 export-bundle.js:formatted:93042)
    at exports.unstable_runWithPriority (VM95 export-bundle.js:formatted:93223)
    at cg (VM95 export-bundle.js:formatted:88300)
    at Jj (VM95 export-bundle.js:formatted:91725)
    at yj (VM95 export-bundle.js:formatted:91443)
    at Ig (VM95 export-bundle.js:formatted:91208)
    at bk (VM95 export-bundle.js:formatted:92650)
    at VM95 export-bundle.js:formatted:92731
    at Nj (VM95 export-bundle.js:formatted:91474)
u @ export-bundle.js?cdv=737:38618
v @ export-bundle.js?cdv=737:38619
exports.unstable_runWithPriority @ export-bundle.js?cdv=737:38625
cg @ export-bundle.js?cdv=737:38418
Jj @ export-bundle.js?cdv=737:38544
yj @ export-bundle.js?cdv=737:38535
Ig @ export-bundle.js?cdv=737:38526
bk @ export-bundle.js?cdv=737:38577
(anonymous) @ export-bundle.js?cdv=737:38580
Nj @ export-bundle.js?cdv=737:38536
ik @ export-bundle.js?cdv=737:38580
exports.render @ export-bundle.js?cdv=737:38586
(anonymous) @ VM319:29625
(anonymous) @ VM319:29652
__webpack_require__ @ VM319:20
(anonymous) @ VM319:84
(anonymous) @ VM319:87
p @ jquery.js?cdv=737:3
globalEval @ jquery.js?cdv=737:3
text script @ jquery.js?cdv=737:11
Qb @ jquery.js?cdv=737:11
A @ jquery.js?cdv=737:11
(anonymous) @ jquery.js?cdv=737:11
load (async)
send @ jquery.js?cdv=737:11
ajax @ jquery.js?cdv=737:11
ajax @ main.js?cdv=737:448
loadBundleScript @ main.js?cdv=737:461
init @ Pages.js?cdv=737:19
(anonymous) @ util.js?cdv=737:30
execCb @ require.js?cdv=737:1696
check @ require.js?cdv=737:878
(anonymous) @ require.js?cdv=737:1139
(anonymous) @ require.js?cdv=737:134
(anonymous) @ require.js?cdv=737:1189
each @ require.js?cdv=737:59
emit @ require.js?cdv=737:1188
check @ require.js?cdv=737:938
enable @ require.js?cdv=737:1176
init @ require.js?cdv=737:788
callGetModule @ require.js?cdv=737:1203
completeLoad @ require.js?cdv=737:1611
onScriptLoad @ require.js?cdv=737:1717
load (async)
req.load @ require.js?cdv=737:1942
load @ require.js?cdv=737:1685
load @ require.js?cdv=737:834
fetch @ require.js?cdv=737:824
check @ require.js?cdv=737:856
enable @ require.js?cdv=737:1557
(anonymous) @ require.js?cdv=737:1161
enable @ require.js?cdv=737:1113
completeLoad @ require.js?cdv=737:1590
load (async)
(anonymous) @ require.js?cdv=737:1460
setTimeout (async)
req.nextTick @ require.js?cdv=737:1815
localRequire @ require.js?cdv=737:1449
requirejs @ require.js?cdv=737:1797
loadTempl @ util.js?cdv=737:21
loadTemplate @ util.js?cdv=737:64
(anonymous) @ main.js?cdv=737:294
d.complete @ jquery.js?cdv=737:6
i @ jquery.js?cdv=737:3
fireWith @ jquery.js?cdv=737:3
i @ jquery.js?cdv=737:6
r.fx.tick @ jquery.js?cdv=737:6
eb @ jquery.js?cdv=737:6
requestAnimationFrame (async)
r.fx.start @ jquery.js?cdv=737:6
r.fx.timer @ jquery.js?cdv=737:6
kb @ jquery.js?cdv=737:6
g @ jquery.js?cdv=737:6
dequeue @ jquery.js?cdv=737:6
setTimeout (async)
(anonymous) @ jquery.js?cdv=737:6
each @ jquery.js?cdv=737:3
r.fn.delay @ jquery.js?cdv=737:6
(anonymous) @ main.js?cdv=737:291
animate @ jquery.js?cdv=737:6
handleLoadPanel @ main.js?cdv=737:288
loadPanelFromPersistedSetting @ main.js?cdv=737:1176
call @ util.js?cdv=737:107
(anonymous) @ main.js?cdv=737:364
load (async)
Show 34 more frames
2export-bundle.js?cdv=737:38505 TypeError: Cannot read properties of undefined (reading 'length')
    at Object.t.getWeekArray (VM95 export-bundle.js:formatted:11383)
    at t.value (VM95 export-bundle.js:formatted:36189)
    at gi (VM95 export-bundle.js:formatted:89861)
    at fi (VM95 export-bundle.js:formatted:89851)
    at Rj (VM95 export-bundle.js:formatted:92228)
    at Qj (VM95 export-bundle.js:formatted:91672)
    at Kj (VM95 export-bundle.js:formatted:91665)
    at yj (VM95 export-bundle.js:formatted:91423)
    at VM95 export-bundle.js:formatted:88329
    at exports.unstable_runWithPriority (VM95 export-bundle.js:formatted:93219)
Ci @ export-bundle.js?cdv=737:38505
Xi.c.callback @ export-bundle.js?cdv=737:38522
Cg @ export-bundle.js?cdv=737:38427
Ji @ export-bundle.js?cdv=737:38508
Sj @ export-bundle.js?cdv=737:38551
(anonymous) @ export-bundle.js?cdv=737:38419
fg @ export-bundle.js?cdv=737:38419
gg @ export-bundle.js?cdv=737:38418
enqueueSetState @ export-bundle.js?cdv=737:38428
E.setState @ export-bundle.js?cdv=737:38165
onStateChange @ export-bundle.js?cdv=737:13722
dispatch @ export-bundle.js?cdv=737:10020
(anonymous) @ export-bundle.js?cdv=737:64716
dispatch @ export-bundle.js?cdv=737:10405
(anonymous) @ VM319:6238
tryCatch @ export-bundle.js?cdv=737:37237
invokeCallback @ export-bundle.js?cdv=737:37252
publish @ export-bundle.js?cdv=737:37226
flush @ export-bundle.js?cdv=737:36956
characterData (async)
(anonymous) @ export-bundle.js?cdv=737:36928
asap @ export-bundle.js?cdv=737:36880
fulfill @ export-bundle.js?cdv=737:37179
handleMaybeThenable @ export-bundle.js?cdv=737:37143
resolve @ export-bundle.js?cdv=737:37156
resolvePromise @ export-bundle.js?cdv=737:37287
success @ sf.js?cdv=737:51
load (async)
rawCall @ sf.js?cdv=737:89
call @ sf.js?cdv=737:100
get @ sf.js?cdv=737:116
(anonymous) @ VM319:3420
initializePromise @ export-bundle.js?cdv=737:37286
Promise @ export-bundle.js?cdv=737:37702
get @ VM319:3419
getPage @ VM319:1238
(anonymous) @ VM319:6237
tryCallTwo @ VM319:4454
doResolve @ VM319:4609
Promise @ VM319:4475
loadPage @ VM319:6211
(anonymous) @ VM319:6366
(anonymous) @ export-bundle.js?cdv=737:64713
(anonymous) @ export-bundle.js?cdv=737:10256
onLoadPage @ VM319:15292
(anonymous) @ VM319:14932
load (async)
get @ VM319:3419
getPageList @ VM319:1402
(anonymous) @ VM319:6271
componentDidMount @ VM319:14930
load (async)
load (async)
load (async)
setTimeout (async)
setTimeout (async)
Show 37 more frames
    at t (VM95 export-bundle.js:formatted:93067)
    at MessagePort.T.port1.onmessage (VM95 export-bundle.js:formatted:93166)
this still looks like minification is turned on.
I have angular 10 sections on the website, which are always minified (prod). I built them with out minifying. Cleared browser data, disabled Composite Files, restarted the website. I still have errors, but the different browser consoles shows different errors.
On Chrome and Edge, I am getting the same error as my first post on the reducers.ts file, line 107, which is the last line in the file.
On Firefox, I am getting the error with export-bundle.js and the file still looks like minified. Not sure why it is still minified, minification is turned off.
    u http://localhost/DesktopM...dle.js?cdv=743:38732
    v http://localhost/DesktopM...dle.js?cdv=743:38733
    unstable_runWithPriority http://localhost/DesktopM...dle.js?cdv=743:38739
    cg http://localhost/DesktopM...dle.js?cdv=743:38532
    Jj http://localhost/DesktopM...dle.js?cdv=743:38658
    yj http://localhost/DesktopM...dle.js?cdv=743:38649
    Ig http://localhost/DesktopM...dle.js?cdv=743:38640
    bk http://localhost/DesktopM...dle.js?cdv=743:38691
    ik http://localhost/DesktopM...dle.js?cdv=743:38694
export-bundle.js:38732:196
TypeError: p is undefined
    getWeekArray export-bundle.js:5093
    value export-bundle.js:5097
    gi export-bundle.js:38592
    fi export-bundle.js:38591
    Rj export-bundle.js:38673
    Qj export-bundle.js:38656
    Kj export-bundle.js:38656
    yj export-bundle.js:38649
    fg export-bundle.js:38533
    unstable_runWithPriority export-bundle.js:38739
    cg export-bundle.js:38532
    gg export-bundle.js:38532
    Ig export-bundle.js:38640
    enqueueSetState export-bundle.js:38542
    setState export-bundle.js:38279
    onStateChange export-bundle.js:13808
    dispatch export-bundle.js:10186
    createThunkMiddleware export-bundle.js:65052
    dispatch export-bundle.js:10536
    loadPage index.html:6238
    tryCatch export-bundle.js:37351
    invokeCallback export-bundle.js:37366
    publish export-bundle.js:37340
    flush export-bundle.js:37070
    useMutationObserver export-bundle.js:37037
    export-bundle.js:37094
    export-bundle.js:36953
    export-bundle.js:36955
    export-bundle.js:38127
    __webpack_require__ reducers.ts:35
    export-bundle.js:65071
    export-bundle.js:84
    export-bundle.js:87
export-bundle.js:38619:195
    export-bundle.js:84
    export-bundle.js:87
    u export-bundle.js:38732
    t export-bundle.js:38733
    onmessage export-bundle.js:38737
    EventHandlerNonNull* export-bundle.js:38737
    export-bundle.js:38744
    export-bundle.js:38713
    export-bundle.js:38423
    export-bundle.js:5300
    export-bundle.js:64180
    export-bundle.js:84
    export-bundle.js:87
Can the issue be with Redux reducer (I am not much familar with it)? What does export-bundle.js file do? Why the Firefox shows different error than Chrome and Edge? This is bogging me down for few days now, any help is greatly appreciated.
Also, is there any other way to access page settings, other than the IFrame?
